Brooklyn Tow
9 11 Never Forget
Maybe add KOKO proceedure to the "Timing the DS4 Injection Pump" sticky/thread.....I mean if you feel like it.
No prob, and good question(s) - they will need clarification for all users of GMTDScan Tech
- BASE timing is my descriptor for the mechanical IP position wrt crank TDC, but you won't see that in any scantool
- we don't actually know (pun intended!) what that "actual" IP timing number represents, but it may be the count on the hi-res 512-slot or low-res 64-slot timing section of the optic encoder disk - iirc the parameter value just turned up in Stefan's scantool, so we discussed it and decided he should label it and leave it in there for future - it is not in the TECH2 heirarchy - I haven't tho't about this stuff in a long while, so for now just ignore "actual" ip timing in GMTDScan - 'measured' and 'desired' are the parameters of note
- GMTDScan measured is our ACTUAL, his desired is our DESIRED - some other scantools also refer to actual as measured IP timing
And, remember: TECH2 prevents any timing adjustments if ECT is below ~172*F - very few of the aftermarket copies, incl GMTDScan Tech, have that safety limit, so always do a scan to verify ECT is above that minimum before proceeding with any timing adjustments
jd
My GMTDScan displays timing as Desired and Actual in the timeset screenshot.
Leo
Will do , louis
Welp, Leo, guess I'm gonna have ta bite the ole bullit, crack out the laptop and fire up the GMC and GMTDScan Tech - come to think of it, mine is one of the original versions, v1.0.1.0, several years old, so prolly best if you guys post up your versions, so we can all start on the same page
Lessee, I've got so many serial\ALDL\USB\DLC cables that I can't remember which is which - I've got one here that resembles a Swedish personal feminine vibrator toy - iirc, that's the one for GMTDScan Tech, but seems like there was one for GMTDScan Basic, both with 12-pin OBD1 connectors - yeah, 12-pins - I've only got 6 of those, so that oughtta make it easy, right?
I tell ya, folks - old age ain't all it's cracked up to be..............
Almost fergot: anybody wanna post up that OBD2 koko fingersy\footsie thingy, so I can at least get that right?
That is how mine displays in timeset, but only in timeset. In the dashboard, snapshots, everything else, it reads measured and desired. Since I'm trying to diagnose what my searches have indicated as a possible timing problem, I am using dashboard and snapshots to get all parameters during the condition, and that is where my confusion is (well, was).
Thank you for the explination, gmctd.
BTT - anybody down and pat on the koko fingersy\footsie thingy? Need to post it up for reference - iirc, it's key on-key off several times while mashing the loud pedal for umpteen seconds or so
Thanks - to be clear, is sequence 3 'release pedal for 30 seconds' or 'release pedal after 30 secs'?
