buddy
Active Member
???? Now i'm lost and haven't a clue what you are getting at
Sorry to confuse you.
Its the point I have been trying to make from the get go, that PCM makes injection timing whatever it wants regardless of base timing. But then someone again comes in saying Im completely wrong, I dont understand, and then ends up saying it himself.
The PCM sets injection timing to desired programmed timing with the stepper motor regardless of base timing. So to get this extra performance at the top end you need to see actual 8.5* when the desired is 0* in time set.
The parallel with the vacuum advance unplugged is what I was paralleling to stepper motor being disabled, to where it can't change the timing. Its not entirely accurate, I apologize for saying it that way.
You had stated you can get -1.94 TDCO when at 3.8* base timing by revving engine a little and thats what you would do, but that is not the same as -1.94 TDCO at 8.5* base timing. So I wanted someone to explain the difference, which is the max advance ceiling.
So I asked the questions to have it come from gmctd instead of me saying it and someone poking holes in the wording.
