Rodd
Recruit
I have been giving this some thought and have decided to post it here for opinions. At the other place GMCTD posted the facts/mysteries about TDCOffset. Although it was helpful I don't know if I fully comprehend it. I actually started thinking about this about 6 months or so ago when I posted my data from my scanner and GMCTD said the timing was a little off. I'm thinking I may have been wrong in the process.
After replacing my IP I set the TDCO at -1.93 and then set my timing. Could that make the timing be off? What if I had set the TDCO at the stock -.50 to -.85 range, then set the timing and then drop the TDCO to -1.5 to -1.93 and not reset the timing. Would this change the timing or keep it where it was set.
Thanks!
Thanks!
