Acesneights1
Picture what Bison did but not having the bolts welded to the prybar.
IP pump was working fine before I started the cooling upgrade with changeout of the timing chain.
I would "think" if it was a tooth off it would not run at all. White smoke is antifreeze. Greyish smoke is raw fuel.
how does it sound like ? Like it's knocking ? where are you located ?
"Turbovanman, in comparison to the timing chain I took off, the new one was as tight as that a$$ in your avatar.
Like my wife, the IP gear only went on one way and that is with the peg in the elongated hole."
Good analogy!!! ):h
Timing may have been set one time when the chain was already worn, the IP only has to move VERY little to change timing a lot. Retiming with tight chain might just do it.
Getting GMTD ScanTech is nice to have any ways if you read the site description. You do need the Scantech version not the Basic version to set timing though. $200. well spent and less trips to the stealer.
Funny stuff up there Big T!!!!!!!!!!
Elaborate more about the rotation of the pump you did, how much did you move it? more than 1/16-1/8 " ??
So you dropped it off, they let it sit, pulled it in hours later, and tried to time it? Call or go down there tomorrow and find out if he let it get to 180 degrees. I don't think the computer will let it time otherwise, I know it wont on OBD2.
IIRC on the 6.2s which probably hold true on these as well when they sound a little "too smooth" and are difficlut to start the IP usually needs to get advanced toward the D?S IIRC. You may be able to just bump it a touch but I'm not sure(well don't remember what I read) how to get the ECM to relearn the new position without being commanded by a scan tool. LIke you said, if time is on your side just order GMTDscan. He emails you the program so you'll get that instantly but the cable takes a little time as it's coming form sweden or something. Don't rmemeber how long it took but I don't think it was that bad. There are other places to get that cable I think as well and you can just buy his software but I chose to get both form him so I knew it would work without issue. I did a htread somewhere here I think on installing it. Gotta watch the com port config.
Dealerships are nothing but robbers without guns. I'd say 80% of the members here ended up here after being raped at the dealer.
Jumping in late here but I would check all the electrical connections make sure there clean and tight. The tdco is stored in the pcm and doesn't change until commanded. And mine ran fine way way off of optimal I was at +3.46.The little bit that you desribe moving the cam gear shouldn't have affected the timing that much. Sounds to me like more of an electrical problem ie crank sensor, optical sensor, etc
