bowtiebutler956
Active Member
Nate if that block is still crack free after all this time, there is a good chance it will stay that way for a long time to come. Have you already cleaned all the mains, and done a thorough inspection? Same with the heads, if they're still crack free, you should be able to get a good service life out of them. You certainly won't loose any power going from 6.5 to 6.2, so I say go for it. If the mains are crack free, I would think a girdle would help them stay that way. I believe the injector angle is slightly different on 6.2 heads, so clearances will be tighter on the turbo side, but they should fit.
Nice score!
Matt
Nice score!
Matt
