Chevypoor
Active Member
Been having some running issues of late as discussed in another post. The temp gauge seems to reading ok but she has that sluggish feeling and when you open the hood you cannot touch the motor. Decided to install the 2000 wp and Dmax fan and Hayden clutch from Gertie to see if she would cool down on Sunday. I decided to replace the ip as I had a brand new one left over from Gertie as well. Also wanted to check the timing chain out. She had less than a 1/4" of slack so I left it alone. Replaced the front seal and installed new GM Ac Delco damper and damper pulley. Swapped over the front coolant bridge with the 190* t-stat from Gertie. Put everything back together and cleaned the air filter. Started up great and in general she runs like stink now. Hooked up the Scan Tech and after about ten tries got the TDCO to read -1.94. All in all a much happier truck.
BTW checked the FFilter and it looked good... only slightly grey. Maybe I just need to short change her a few times.
