turbonator
Your .005" fall right in the middle of what we got here for specs, .004" to .006" on the rears. Maybe with the block-fill the cylinders deformed a bit down low (at concrete) or the fill retains heat more. Either way, think that a bore would be a good precaution, and go on the high side of clearances.... we only filled 3" (bottom of water-pump holes), but after seeing the galling that you got, we might be obligated to bore too.
Still am very impressed that neither the crank nor the block let go (we have not broke either yet), being that those two are what many of the horror stories are about....
