buddy
Active Member
From real world experience i have never seen a set of compound turbos get anywhere close to a 1-1 drive ratio. They end up closer to 2-1 drive ratio than they are 1-1. Your science and math have nothing on real world experience.
And the knowledge in your experience may not be the kind I care about. All the stuff you talk about pushes for the extreme performance. You have to know where the turbos are most efficient and make sure they are in that range. Are you even measuring drive pressure, do you have some data to provide? The compound setup will be more efficient than a single, so if your compound is 2-1, then your single was probably 3-1 at the same boost. But as of now, at the boost levels most of us run on a 6.5, our single turbos are already in the 1.1-1 to 1.2-1 region, because we dont overspeed them. The small GM turbo you could get to 2-1. So take two turbos that are operating in their 1.1-1 ratios and you will end up even more efficient.
Its kind of like the real world guy thinking the pressure at TDC was just the pressure at BDC multiplied by the CR. Im sure there a many expert machinists and technicians out there that do think that. There are a lot of little misunderstandings like that in the real world. There is a difference between expert technician and design engineer. The technician will understand practical things better from experience, doesnt mean they understand what is happening from following the instructions they have. The engineer usually lacks some practical knowledge on what trial and error has taught the technician.
