DZZ71
"Living The 6.5 Dream"
Same here I havent even had time to install most of the extras I have sitting in the shop. Had to put it back inservice the day I got mine going.
I'm getting the pistons shaved .045 thousands. They are all getting reused,except 2 are from a parts motor . So far I collected 6 straight rods,but will have to pull 2 more from another one of my blown 6.5's. I discovered that 6.5 rods are ofset,the flat sides go against each other. I should be close to 18-1 with stock thicknes head gaskets ,and .010 decked block. Pistons should end up about .030 below the deck. That would give me .075 squish. I didn't break any rings, so I plan on reusing them. Not sure about the rod bearings,I might just flip them. One or two of the main bearings show some slight grooves of copper. I will look into some bi metal bearings,instead of tri metal.
It's a GIF link - click on itcan't see pic/attachment
