I will lower the compression,but not sure how far. I'm going to check if the pistons may have hit the heads ? I know they were pretty close. So far it is obvious that they were bent for a while,#8 piston was rubbing the crank. Also it had a knock when cold,even before I gave it more fuel. The first I heard the noise it was just idleling. It could be that at high rpms,everything stretched enough to let the pistons hit the heads ? When I replaced the head gaskets every thing looked fine,and the new gasket was thicker,but may have compressed to thinner than the copper gaskets.
