3500GMC
What T F, over
Which oil port would you hook the turbo up to? There are the two oil cooler lines, then there is one hole that did not have anything in it when I got the engine (not sure what was hooked up there, if anything) then the plugged hole.
GM used the one on the right front of block just ahead of the cylinder head. Then some newer blocks had a port in the 'valley' of the block. If your 6.2 is an oldie like mine it had neither so I just T'd into the oil pressure switch port on the top left rear of the block.
