- Staff
- #21
So you did your Motor Mounts "3" times.....Used both poly inserts and finally decided to go with the "Made in China" mounts they sell at the dealer?
GM P/N number for both sides are the same (for 2 wheel drive, 2X4)....Correct?
Well that about seals the deal for me, OEM/China Mounts it will be......Your a Maniac!! I can't believe you did mounts 3 times.....How much time between each swap, did you give it a little time to get use to the feel, or did you know right away?
For me it was an immediate difference between the mounts. I did run it for a week with each set, and I decided on running teh GM made in CANADA mounts that GM still offerred in 09. I still have a set of low milage made in canada mounts out in teh shop that have 3/16" limiter blocks installed in them, and I also have a set of the poly inserts like teh ones in Kennedy's write-up with less than 500 miles on them if anybody wants em(there taking up space in teh tool box that I would like to get back).
