MrMarty51
A piece of wire about six or so inches long, bent the end one inch at a 90 degree angle, see if it will poke into the hole where the bracket fits to the starter. If it does then install a bolt, if the bracket fits right up to the beck of the starter.
If the bracket seems to want to hang out a ways to be parallel with the back of the starter then a few small washers Might be required between the back of the starter and the bracket.
Most likely the stud had a hex midway to allow for tightening it to the starter, why I suggest seeing if the bracket hangs parallel to the back of the starter. Bracket might have been designed to be properly positioned when it is against something as thick as that hex on the stud.
