Acesneights1
Hell, I put my motor in by myself and I'm a worn out old man....No the Luk i picked up was defective. Cracked disc on the edge. Returned it defective.
Ordered a ~$180 RhinoPac kit # 04-087 which is 6.2 specific(unlike the autozone one i had which was gasser/diesel). First kit, cracked disc on the edge. Was able to lift a roughly quarter sized piece of clutch material off with my finger nail in the crack.issed:
Second RhinoPac, same issue, same part #04-087, but not as bad. Cracked is cracked, and i won't run a damaged disc.rrr:
Third RhinoPac, different part # 04-122, no disc cracks when it showed up.![]()
I did manage to put a small mark in the very edge of the clutch material with one of the pressure plate lockwashers during install though. :suicide:. It doesn't look to have cracked from what i can see.
UPS sucks. The parts were fine when they left and damaged/broken when they arrived. I just thank the folks that own/run the store that they were willing to work with me. That's exactly why i go back time and time again.
Where-ever you buy from, double check everything over either at the counter or the second it shows up at your door. For something like a clutch, i'd rather buy over the counter. That way if it's defective you can show the parts guy and they can't say "well you did that when you handled it/installed it" like an internet retailer has the option of doing.
Just be careful if you go RhinoPac. The clutch is a 12" clutch, not 11 3/4 or 11 7/8 like most. That little extra gets the disc very close to the pressure plate mounting bolts. In fact there was a bulletin in the box that said to be careful that you don't hold the disc to the flywheel with the bolts since the clearance was so tight.
Also make sure the release bearing is correctly installed(this goes for any brand). Im not sure if this goes for the NV4500 as well, but in the SM465 clutch fork there's a little spring clip where the TO bearing attaches. The spring clip must be under the lip of the TO bearing. Over it will cause hard pedal and release issues.
Here's the bulletin from LUK.
http://bulletins.schaeffler-aftermarket.us/displayTB.phtml?number=LB179
Still haven't gotten my damn trans back in. I've been working on the turbo swap in my spare time. Can't really put the trans in myself. well correction, i could, but i'm not risking the bitch falling on me and crushing me. I'll wait until i can get a second set of hands for a day.
