iamdave0887
Here Comes Chaos.....
8,000 miles...
8,000 :cussing:miles......
:suicide:
That's all i got out of the Autozone clutch kit.
It was a brand new throwout bearing when i installed it less than 2 years ago.
I knew it wasn't happy when i started getting chirping noises a few months ago. I knew it was even more unhappy when the chirping noises went away.
Today i push the clutch in to pull out into the street after getting lunch with a friend and i hear SQUUEEEAAAAALLLLL!!!
Then it started squealing like all hell with the clutch out and became 10x worse when i push the clutch in.
Double ****!!!
Now i have to drop the entire trans/t-case to change the damn throwout bearing.
I'm just going to do it right and pull everything. Trans, bellhousing, clutch, flywheel, the works.
I'll be bringing the clutch kit back to autozone, dropping the bitch on the counter and demanding my money back. I should not have to deal with this shit with not even 10K on the entire thing.
Best part is, I'm STILL waiting for my gauges for the turbo swap. It's been close to a month, and 2 different companies i've gone through, and they still aren't here.
Triple ****!!!!!
I wish i could say this is the first time i've had an autozone part go to shit on me with this truck, but that would be a lie.
First it was the autozone reman master cylinders. I went through 2 in less than 6,000 miles. First failed completely for the rear brakes out of no where. Piston seal must've blown. The second failed around the rear seal so it leaked fluid all over.
Third times a charm? **** that, i got my money back and bought a brand new Wagner master cyl from somewhere else.
I'll be buying another clutch kit from somewhere else as well. I pray this clutch kit is made in America, but i highly doubt that'll happen.
I'll never be buying Autozone anything for anything mechanically related for that truck, or any of my vehicles ever again.
Best part is, I can't drive the 96 because the front tires are all dry rot, and so is the rubber in the replacement harmonic balancer with ~35K miles on it.
**** again!!
With my luck today I'd take that truck out and break the crankshaft into pieces.
Can anyone recommend a clutch kit that'll survive behind a 6.2 TD? I've been looking at a LUK kit from work. I've read the South Bend clutches have LUK branded on them, so going to a SBC would do nothing but cost me more money.
I"m just going to swap all the turbo parts in while i've got the trans/t-case out. On the bright side, I'll have plenty of room to install the new exhaust with no trans or t-case in the way. :suicide:
:suicide:
Double ****!!!
Triple ****!!!!!
**** again!!
