Turbine Doc
Just Another Diesel Guy
Cat = soot trap, scrap it ASAP if U can Diesels don't get hot enough like a gasser for a catalyst core to burnoff the residual hydrocarbons post combustion, add in a bad injector or blowby or bad CDR dumping excessive oil especially in a S truck recipe for plugged cat.
I've been sans cat since 2000 my truck even at 2yrs old then & 37K miles was nearly plugged solid with crud, so get rid of the cat if U can.
If it must be there for appearance sake/inspections core it out then run a pipe thru the shell for best flow with the gutted shell around the pipe and plumb rest of exhaust to that, best however; especailly if going for max power at some point down the line is upgrade to a 4" replacement system with mandrel bent turbo downpipe and crossover pipe.
