GM Guy
Manual Trans. 2WD Enthusiast
I give the ATT a try before giving up on the 6.5L, dont have one, but want one!
as for the 4l80 build imo would be foolish not to upgrade the convertor that includes TCC upgrades as well either big single or tripple disc
I give the ATT a try before giving up on the 6.5L, dont have one, but want one!![]()
joey
i have talk with hughes, TCI, and PATC about convertors i would be geting one built to handle more then what i plan on running through it. both the th400 and 4l80 have problem with the stator suport bushing goign out and allow exsesive play on the front of the tranny
true... im more worried about tranny temps right now
http://www.summitracing.com/parts/DER-14207/
the plan is this.. adds a 1qt or so plus have built in 1/8npt bung for temp unit..
Were you using overdrive?
Try it not going over 4th gear (direct drive)
I am curious what the difference will be
anyone got part numbers for the 9 blade mod and fan clutch?
the problem with the nv4500 is outside the airflow under the truck there is no other means of cooling the fluid...
in all honestly ~14,000lb should not heat up a nv4500 like that.. except for one reason.. hauling something that created alot of wind resistance.
