Will L.
For wheel/tire weight affecting mpg: I put on aluminum rims with 6" wide tread 36 1/2" tall and ran for a
Week. 2 tanks one city driving 1 highway. CompAred to my 2 piece steel wheels with off road tire pattern 12" wide and rubber run flat/bead locks in it. 109 lbs more EACH WHEEL/TIRE.
Lighter & skinny set up tires improved city mpg by 1.2 mpg. The heavy off road monster did better by 1.4 on the hiway. Weight in motion working as flywheel is my theory. I would think those other tires could hold you up some but as much as you are describing???
I hope you found it with all the front end chaos.
