Cranks instanly, runs like a beast. Issue is it has no throttle responce. It is like 2-3k rpm with barley a touch. New IP, acceleratpor pedal, new PCM.
- What were you doing when it happened? Normal driving
- How was the truck running fine before this problem appeared? fine
- Has this problem ever happened before? No, new issue
- Describe any related factors that might be part of the problem. Just started getting bad. Replaced accel pedel.
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N)y PCM short
Diagnostics:
1] Starting:
1a] Does the engine start? y
1b] Does the engine crank over? y
1c] Are your batteries fully charged? y
1d] Have you removed, cleaned, and tightened all battery connections? y
1e] Does your Wait to Start light come on for a time? How long? n
1f] Does your glow plug light come on? y For how long? 15s
1g] Do you see smoke from the exhaust while cranking? What color? n
1h] Does the Service Engine Light Glow during Start/bulb check? y
2a] Can you hear your lift pump working? Y, electric by passed
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? y
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? y
2d] Loosen an injector line and crank the engine - does fuel come out? y
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? y
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) remote
3b] Condition of Extension harness (if used) Vendor or Homemade? Exten/homemade
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. good
3d] PMD Make: D-tech
3e] PMD Age: 6mth
4] Stalling Issues
4a] Do you experience stalling only when hot? n
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) n
4c] Does pouring cool water over the IP seem to help with restarting? n
4d] Is stalling momentary (engine recovers)? n
4e] Does SES light come on when engine hiccups? n
4f] Does cruise control quit working when engine hiccups? n
4g] Does re-starting seem to reset engine, restoring cruise and power? n
4h] Changes to dash lights or instruments during stalling events? n
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? n
5b] Any bubbles or oil film in coolant overflow tank? n
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? n
5d] Excessive white smoke from exhaust on cold start? n
5e] Excessive black smoke from exhaust under hard acceleration? n
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? n
6b] Maximum boost under load? n
6c] Have you added a performance PCM (reflash) or Chip? n
6d] Have you changed exhaust / downpipe / crossover? n
6e] Wastegate – mechanical or vacuum (OEM)? V oem
7a] Single or dual thermostats? Not sure
7b] Have you replaced them lately? Manufacturer of replacements? n
7c] Have you pulled and cleaned Radiator and coolers lately? n
7d] Have you replaced the fan clutch? Manufacturer of replacement? n
7e] (winter) Have you tested your antifreeze? Good to what temp? n
7f] (winter) Are you using a winter grille cover? n
Diagnostics:
1] Starting:
3] PMD / IP Issues
3e] PMD Age: 6mth
4] Stalling Issues
5] Running Issues
