RPM jump with light touch on throttle.
Probably the solenoid went bad, try to spray a little WD40 in there, sometimes it works. You should still check vacum at the pump and the solenoid, to see if the pump is up to snuff (test procedures and vacum numbers, should all be in Tech library)......Once you figure out what the problem is, you could fix it or go Turbo Master
You want to wire the wastegate "closed".....just go easy on the fun pedal.
