jrsavoie
Recruit
Seems to me, if its the 1/8" line, I've got them about anywhere from auto parts stores to building supply or hardware stores.
Amazingly the easiest place to get a ferrule is Lowes. Not as much Home Depot. Auto parts store like Napa should have them but Autozone places don’t.
The other places that has them is semi truck dealership like freightliner, peterbilt, etc. The best place to get them always in stock and lowest price is hydraulic/ hose shops.
28 F out and we got 4” of snow overnight. Went out to start the truck and it fired up immediately with no roughness and no white smoke.
Only thing with oil from the passenger side, I think, is the turbo and the rocker arm cover.
I bought a coolant system pressure pump. It comes with a cap pressure tester adapter too. I have found I needed that tool way more often than I ever figured I would.
It is mighty nice when a system can be pumped to operating pressure then the leak sought out without all the heat.
I was told the old Buick had a bad coolant pump and the radiator needed replacing. After I got it into the garage and started working on it. The coolant pump I had recently replaced it and there was no leaks and the bearing were just fine, and, there was no leaks on the radiator. Coolant pressure pump was mighty handy for that, left it pumped up for two days and not a drip from anywhere.
Had the tires rotated. The tore shop told me there was a bad lower right side ball joint. I also checked that out, ball joints was all good.
And people wonder why i dont hire the mechanical work done. I am getting to where I dont really enjoy doing the mechanics as much as I used to but I sure aint going to trust any shops.
If the valley drain is plugged stuff can run down from there.
@Big T
Did you, or does anyone know how to get ahold of him? Below is a copy/paste from hummer forum today from a reputable guy titled:
Warning: PT wiring solution H1 harness.
I know a few of you are going to go: "Who?"
These guys were around the 6.5 community which goes to show that I found anything you hear from that end of the GMC community you can pretty much ignore for the most part when it comes to our trucks as usual.
Anyways they were selling some H1 stuff on ebay for a bit and their harnesses got good reviews, at least for the non H1 stuff.
I was pretty fed up with the standard GM bullshit group 78 harnesses on our trucks. Bad connections galore and I already went through a set or two over the years.
My gut feeling was this was probably overpriced to begin with and I was just going to buy the tools and equipment to do this myself which is eventually what I'm going to do anyways.
$250.00 well wasted.
Anyways, the connector and cable quality is pretty good, but the starter cable lengths are honestly too long for our trucks [good luck to get it to match placement with our splash shields and original cable routing], and the starter positive lug is too small and requires drilling/reaming up a size or two .
My guess they got some trashed H1 that was missing the oem starter and the splash shields and made a kit and didn't test it on anything else.
The company doesn't seem very active now, I couldn't easily get a hold of their email and when I emailed their sales email I didn't any response. They may be out of business who knows.
They came recommended on some of the 6.5 forums but screw these clowns.
Same problem with 95% of Hummer/hmmwv aftermarket state these days.
No attention to detail. None.
If I get around to crimping a new battery cable set, I'll do a run, they'll match spec and I'll throw a lot of them up for sale and I'll guarantee them.
Could ya send him the link to that hummer forum I posted? Afaik he always does good quality at good prices. I think he would make that dude happy if he knew what was up. Hate to see people upset with purchases and to see a good name catch bad reputation. The only thing he isn’t good at is letting his customers get ahold of him.Maybe Facebook. He is on my friends list. Not sure how much time he spends on the communist site anymore.
Might be like a bunch of other conservatives, and minimizing flaceblook time.
