turbovanman
I has boost, :O)
CR is same piston coatings and piston top design IIRC come into play as well, 6.2 pistons aren't coated for higher temps you see with turbo @ higher pressures,
Since when is the compression the same? Everything posted on here says 6.2 N/A's have higher compression than 6.5's, hence the main reason we can't run high boost. Why are all the 6.2 guys looking for old discontinued lower compression pistons, or using a thicker head gasket or possibly milling the piston to lower the compression?
Edit, found this, compression on a 6.2 is 21.5:1 and "Compression: GM Early 6.5 21.3:1, GM Late 20.3:1, AMG/GEP Marine 18:1"
Turbo van you might want to get up with Bill Heath hes dabbled in racing 6.2 on the strip and may have some good advise to share with you.
I might do that, I have to order a TM from him for a customer.
