Rebuilding a GM8 turbo,show and tell
bison said:
I aint scared to rip anything apart,the DS4 is on the blocks:smile5:
I agree. It was broke when you started... what's the worst that's gonna happen? :D
Good pics and write-up, Simon - thanks. This is going into the 6.5 Technical Library when you're done.
Excellent post i will be rebuilding one shortly out a 98 burban very timely!
Thank-you
next bunch.
Pic 1, clip in place, a good snapring pliers makes life easy,without it is gonna be a bear to get that little thingy in :mad2:
2 and 3 , Intake side brg in,check again for free spinning, put the new spacer(shiny thingy) on top, flat side on the brg,then the new trustplate and torq the screws down(sorry no specs,i use common sense).Stock had tread locker on the screws,i did not use it there,but feel free to do so.
4 and 5, Seal holder,put the remaining 2 seal rings in their respective grooves,check for turning freely with no sideplay,Actually goes for the exh seal ring too.close side play and easy turning.
6, oil it up and work the thingy straight in the endplate,if it wont go, polish the taper edges somewhat so they dont cause a hang up as the rings have to compress to get seated,be carefull not to apply to much pressure or your lookin for another kit to finnish the job.
7, apply a little high heat red RTV to the edge and around the screw holes. a little means a little dont clobber it on.
Put it in place,make sure you line up the big slot in the plate with the slot in the unit and torq it down(again no specs)
Perhaps you could elaborate on what parts failed, and if anything could be done to prevent? Would add to the thread.
Plus I'm curious.
Main thing by far was the screws. Had to be really careful not to strip the heads. The originals were locktited as Bison said. Even on my 2nd rebuild with no locktite they were hard to get out. Also seemed like the piston ring type seals were kinda chincy. I've seen prices from $55 on ebay to $150 on line, and it looked like $30 should have covered it. JMO
last bunch
1 and 2, Place the heat shield over the end and insert the oiled up shaft trough,work it gently in till it bottoms out.
3 and 4, hold the shaft in on the back and place the impeller on the shaft and push it home,apply a drop of tread locker and run the nut snug.
Tap alternately both ends with a nylon mallet or screwdriver handle to seat the seal rings,check for free spinning and torq the nut down,check free spinning again.
repeat the taps till it turns smootly.
5,Check the side play, should be less then half the gap between the edge of the impeller and the edge of the recess.One can measure with a micro meter too,i did'nt bother cause i dont know what spec is supposed to be anyway,i relied on my experience.
6,Give the edge of the housing a lick of RTV or copperkote and bolt the snail house to it and check if the impeller clears the snail shell with room to spare.
7,cleaned up elbow,check for cracks and clean all treaded holes with a tap or use W40 and run the bolts in and out.blow clean with the airgun.
8, 9, and 10,
a peek at the waste gate,if the arm moves freely without excessive play and the seating area of the gate shows no carbon build up i would leave it be.
The finnished turbo,ready for an other couple hundred k.
After install on the engine fill the turbo with oil before hooking up the oil line.
If some one happens to know specs and torque values,feel free to add them on:thumbsup:
A pic of the kit manufactorer.This one is pretty good quality,made in italy(I hope):h)
and while i was at it,i cut up a perfect waste gate vac pot and build a turbo master from it.:D
Thanks again, Simon! Your thread here has been added to the 6.5 Technical Reference Library under T (for Turbo, GM-8).. I learned a lot in this thread, myself!
Thanks for taking the time to do this... Show-and-Tell rulez, as usual!
Jim
This particulair turbo was just stuck cause of carbon build up in the exhaust seal and under the heat shield,all parts exept the one sealring where in exelent shape,Had 268 k on it.
Very good.:thumbsup::thumbsup: I'm licking my chops waiting for the DS4 rebuild thread.:D
nice writeup Simon, If you use a heat gun on those screws with the loctite they will come right out.
I rebuild turbo's, good writeup but I have a few things to add, :thumbsup:
Use a punch and mark all the housings so you can put it all back together in the same relationship, makes reclocking unneccessary.
I highly recommend getting it balanced, they do go out over time, like a car tire, its cheap insurance, if your not, then MARK the compressor wheel in relation to the shaft so it goes back on the same spot. When putting it back together, the compressor wheel moves when being tightened so take that into account.
I like to use anerobic sealer, RTV can get stuck in the turbo or places it shouldn't, the excess anerobic will simply melt and no do any damage.
I like to use ARP Moly lube on the bolts, makes them tighten up alot easier and come apart alot easier too.
Buy a small set of circlip pliers, makes the job 10 times easier.
Measure the bearings, sometimes they send the wrong ones in the kit. The last GM6 I did needed .005" oversize bearings.
Pay close attention to the turbine seal area on the cartridge, this area can get damaged and if it is, the seal will never seal and you'll blow oil into the exhaust. They can bore this larger and if the turbine shaft seal area is damaged, they can also machine that larger.
As mentioned, be very careful putting the rings on, if you over expand them, it can make putting the turbo back together difficult and you can damaged the rings or the hard parts. I've folded over the turbine ring before, :(
