I wouldn't order a single part until you see how your block is going to shape up.
6.5 stock bore is 103mm (4.06inch) First oversize is .25mm if you need to bore the block. I would start with a new 'round' bore, new rings in old egg shaped bores take forever to seat in. Piston slap/wear unseats the ringset on top of that. Blowby out the gazoo...
Top ring is keystone cross section kinda like this, /_\ 3mm thickness Big side, bottom in illustration, toward the piston wall.
Second ring is 2mm thick.
Oil ring is 4mm thick two piece design.
Brand? I like Speed Pro but I'm not sure if they do 6.5 diesel stuff- so probably Perfect Circle would be a good candidate.
I would Definatly re ring it with a hone. I rebuild a 141 and have had no problems yet got 25,000 on it now and driven hard
You should be fine. In extreme cases your block will have a 'ridge' at the very top of the bore. There are cutter tools to remove this ridge if needed. Tool is called a ridge-reamer..
don't hone any more than you have to to clean them up. other wise your removing cylinder wall metal that should be kept to keep clearances
what do you think of this kit : http://www.ebay.com/itm/Chevy-BBC-3...Parts_Accessories&hash=item46017c5c5b&vxp=mtr
I was wondering if it's worth changing the roller lifters too.
Also, are all camshafts the same, or does it exist some torque enclined?
