n8in8or
Ah! I had the same problem. Luckily the pic I took of the engine sitting on the ground showed me what I needed.
You aren't kidding. Glad to see you're making progress.Looking at pics on the computer is much better than the phone.
Oh now I see.I thought I would pressurize the oil system before installing the valve covers, good thing I did as #3 intake valve has no oil flowing through the push rod. The rod is open. Oh joy.
When i did my engine i took all the lifters apart and cleaned them out,..was lots of gunk in there!I thought I would pressurize the oil system before installing the valve covers, good thing I did as #3 intake valve has no oil flowing through the push rod. The rod is open. Oh joy.
I had thought about doing it, now I wished I had. Shouldn't cut corners.When i did my engine i took all the lifters apart and cleaned them out,..was lots of gunk in there!
In hindsight I should have, I was trying to save time. I pulled the heads and cleaned all the lifters, waiting on new gaskets now.Kinda surprised you didn't just go new on lifters right off the bat.
There's no need to pull the heads to get the lifters out!In hindsight I should have, I was trying to save time. I pulled the heads and cleaned all the lifters, waiting on new gaskets now.
It's a lot easier and I was having second thoughts on reusing the gaskets after the first block issue. With studs, if they leak I have to pull the engine.There's no need to pull the heads to get the lifters out!
Don't you just love it doing everything twice!It's a lot easier and I was having second thoughts on reusing the gaskets after the first block issue. With studs, if they leak I have to pull the engine.
It's a real pain, but better now than in 6 weeks or months.Don't you just love it doing everything twice!
You're almost an assembly worker now,...mebbe there's an opening at GM for ye
I would think thats a wise choice! Don't give Murphy's Law a chance to take affect!Original torque on the gaskets was just over 75 ft/lbs. I thought going to 110 would still be OK. On second thought the way things have been going, no way.
