Will L.
Can you do a video when you get into the other side? That way everyone else running them can see what to watch for, and maybe send video to mfr so they see what's going on.
They (and Leroy) were great to work with on this issue. I'm sure there won't be a problem.Did not see this went to page 7 (my page 7) til just now. After I saw Tim's post I got on the phone with HS. They close on Friday's at 11am
So should here something back on Monday.
How far from Summit are you? You could probably drive there and pick one up from them and be back in business today.My cam finally came Tuesday. I just got it back in the engine tonight, but I have to degree the cam. I don't have the tools to do that, so I have to order the wheel and wait for it to get here before I can go any further[emoji36]
I'm close enough that I ordered last night at 9PM and they will have it at my door today... For free[emoji57]How far from Summit are you? You could probably drive there and pick one up from them and be back in business today.
I love Summit. I have a degree wheel kit from them but haven't used it yet. Have fun!!I'm close enough that I ordered last night at 9PM and they will have it at my door today... For free[emoji57]
I got the head studs, lifters and lifter guides all installed, on one side, today........ But.... In light of talking about the amount of money I'm spending on this thing, I am going to be pulling the cam back out and sending it to R&D IDI Performance to have him grind a stage 1 cam that he designed for the Fords to "test" in a 6.5. Sounds like he's had pretty good results with it in the ford idi's so we'll see how it does in my engine.
I will be setting the cam to the grinders specs. For the Fords he just has them make the dot on the cam gear one tooth off and that gets it where it needs to be. Since this is on something new, he gave me the specs to set it at to make sure it is put where it needs to be.When you say your going to degree the cam, do you mean read it and see what lift & such are... or is the cam or gears adjustable and you will set it per the grinders specs??
