buddy
Active Member
It sounds too advanced even after you warm it up, I don't like mine like that so I idle between 7 and 10 degrees advance when warm on tunes meant for daily driving. Thats in the PCM, setting the TDCO won't change it. Youre probably 11 degrees advance at normal idle and when cold could be closer to 15 degrees. The thing is, thats cam timing, which is only half of crank, so idling at 22 degrees crank advance sounds crazy, but it does work for being a little more responsive. Although at less advance engine sounds better at idle and revving.
But it won't make startup be bad like that, thats more like an IP issue, and the PCM data could be revealing.
