buddy
Active Member
After the plugged in test, the next morning do a test with CTS and IAT unplugged and no block heater.
which one is the CTS again ?
Now WITHOUT turning this into a pissing match..Can anyone speculate or know FOR SURE if the ecm from my 1998 k2500 be swapped into this Dually ? Swapping ECM's might show if Heath's tune is asking more of htis truck than it should as well as giving me a peak at what the burb might run like tuned. The burb is stock. Also I have never screwed with the Theft relearn nor do I know what it is or what it does. I don't want to swap ecms and then screw something up and have both trucks down. I drive 60 miles a day round trip and that is a rough ride in a the CUCV....
BTW when I asked Bill H himsef, He said no.
Copied and Pasted from Nelson Performance, can be found lots of places on the net.
ATTENTION: Your vehicle may not start unless this procedure is performed.
GM introduced an anti-theft system in 1996 and newer vehicles.
In order for your vehicle to start, you must perform the passkey relearn procedure.
If your vehicle’s battery is low, it is recommended a battery charger be hooked up at this time. This Procedure will take approximately 20-30 minutes.
After your PCM is installed, please perform the following.
You may want to be outside your vehicle so shut the door, roll down the window.
PROCEDURE:
Insert key, attempt to start the vehicle and leave the key in the ON position.
In some vehicles, the Battery and Security light will blink for several seconds, and then shut off.
Then the Security light will then remain ON. Leave the ignition ON until the Security light goes OFF. This will take more than 5 mins.
When the Security light goes OFF, turn the ignition to the OFF position.
Leave ignition OFF for 20 Seconds.
Attempt to start the vehicle again and leave the key in the ON position.
Turn the ignition to the OFF position for 20 Seconds.
In some vehicles, the Battery and Security light will blink for several seconds, and then shut off. Then the Security light will then remain ON. Leave the ignition ON until the Security light goes OFF. This will take more than 5 mins.
Once this entire procedure has been completed (three times) your vehicle will start on the fourth attempt.
Note: Some vehicles perform the relearn in a different sequence. You may notice your security light, battery light and abs light will alternate. Once the security light is left out of the sequence that is considered one step.
Repeat the procedure two more times and on the fourth time your vehicle will start. TD edit insert Should for Will start, most times is does, some times it never starts be sure to tell you programmer you had a theft deterrent truck when ordering they should know when they plug in the VIN I got one from BD once that would never learn the td code so I sen it back also if you screw up the on & off sequence you may have to start all over again
What is that 'typewriter' clicking noise during the warm up smoke show? White smoke would be retarded timing as well as high boost and high egt's. Single cylinder not firing gives me puffs after startup. So it acts like all the cylinders with the steady smoke. Have you inspected the timing chain on this one?
Maybe you got one good injector (or popping high) and the rest are (bad) low pop injectors?
