Random question and ,BTW, I hate you bastards!
Wow. I guess I got here by accident. I was looking for a fuel economy parts, mostly of the bolt on kind. When my project (6.5L Suburban fuel economy experiment) got to the turbo and the desire to omit the vac pump and all that jazz, I asked Kennedy what options were out there. He hooked me up with turbine doc and slim shady just before the ATT was being offered via walkingJ. I guess this internet stuff is like dating, timing is everything.
On topic... Since in vehicles, the launch is such a small window of time, it seems a waste to give up either power or fuel economy on the whole, to maximize the hole (shot) in a compromise. What if one used a blower in parallel with a turbo. I believe I read some time ago that VW was going to do this (perhaps in an engineering magazine or diesel progress?). If you could uncouple the blower as rpm increased, you could gear it tall enough to be effective at the low rpm launch, then get it out of the way once the turbo was up to speed. I'm not sure how you could manage the blower to assist a high speed, low power launch? Example might be coasting down hill at 60 mph as you approach a 2-lane passing opportunity, then stomp on the pedal? Would the turbo do it, or would you need some blower assist? Could this be done, or more accurately, could this be done in a simple manner and not cost a fortune?
A simple electric clutch like theA/C compressor has would do for the engage + disengage, many blowers on the market now to match the desired capacity...
computer control for setting in/out function; go for it, we'll cheer you on.
do-able, definetly.
Glad you offered that up as built properly, that gets lost in translation sometimes when folks read 25 psi boost and want to apply directly to theirs.
Would be good for him to join our crew make sure you extend an invitation to him.
More on my Friends motor. It has the 406? block with the hi nickel content. The only block newer is the P400. Running Mahle pistons and with the extra relief in the combustion chambers his compression is 17.7/1. The block has all studs for the heads and the main brgs and gear drive for the cam. He said the only limits he has is with the injector pump and the rods. The stock rods are about maxed out but Carillo makes a set for $1K that are pretty bullet proof and that Scat makes a good forged crank that will get the job done. He is in the process of getting a new set of heads for it and is considering making a set out of aluminum.
