Will L.
Oh, on the heater core- Just make sure the heater is on max. This will circulate the cleaner and rinse water through the heater core.
Returned the Dexcool to Walmart. Here are my Choices at Walmart:
View attachment 66623View attachment 66624View attachment 66625View attachment 66626View attachment 66627View attachment 66628
I have never tried Asian, which I find intriguing.
There is a second Walmart in Missoula which I will check today. Does Costco carry coolant? Still looking for distilled water.
AH, NTC where the temps can go from hell hot during the day and ice cold at night..Now, Death Valley or Ft. Irwin where summer daytime temps can and often do hit 120°+F (I still vividly remember the day out in "the box" at Ft. Irwin back over Labor Day weekend '96 in the shade of the cammo netting stretched between the two APC's at the TOC the wetbulb thermometer reading 131°F!) and NO overheating issues with our HMMMV's, or other diesel powered vehicles because they were all running a 70/30 mix with Water Wetter, @Will L. (Say THAT 3x's fast, Water Wetter Will! )
Yeah, like in less than 60 minutes after sunset. Easily goes from 115-117°F to 50-55°F in 30-40 minutes and sometimes even dips into the 40's!AH, NTC where the temps can go from hell hot during the day and ice cold at night..
They sure are purdy.
Yuppers, I am well satisfied with the radiator I got.The champion radiator is working fine. No leaks. Dash temp gauge pegs at 185. Like Les said, if it were truly a replacement, they should have the right fittings for the transmission lines welded in so a reducing fitting is not required. Similarly, the fitting for the coolant overflow should be the right size = bigger. Other than those issues, it's functioning, so I am happy with that and thanks for the recommendation and advice.
Understanding what the pump is and what it’s feeding...would be interesting to see what the size change does. It’s a restriction in flow or an increase in pressure. But depending what the pump itself is- and what it feeds- makes all the difference
