robzombie4551
robzombie4551
Yes, but mark where you have it set now so you have a reference and can put it back there if it runs worse.
Where'd you get that kenny, I use the gmtdscan but that thing looks cool and I've never seen one like that before.
well before he turned up the injection pump it ran great. he then changed a valve cover gasket when he did he turned the injection pump up, but when he was putting the injection lines back on he forgot to hook one of them up. i hooked it back up and started it up and it ran better i just wasn't sure if the timing had to be adjusted when the pump was turned up.
i just ordered a egt gauge and boost gauge so i'm gonna hook them up when they come in. whats a suggestion on egt placement?
