I have run low compression in several motors, all have used the piston top design I offer, granted all these used DB2's that were putting out more fuel than a DS4 can, and all were using HX35/40 hybrid's with different than stock Holset blades. I found in all instances the motors were quieter and had more power than needed towing @20K plus..
All the motors are still in use and performing like new.
I think when looking at the stock precup & piston design everything else also needs to be considered, small turbo that was used, built to conserve fuel not make loads of power, pass smog tests, etc. For what the motor was designed to do the high compression, cups, piston design worked well, but...
Now more than double or triple the amount of air & fuel along with boost pressures that same design might not be optimum.
It's a fact that a larger container will hold more product, air & fuel in this case, what makes the power we all look for??? more air & fuel...
The cylinder pressure calculator in the download page on my site will spit out pressure numbers for an array of different setups, cylinder pressure, or toooo high of pressure will effect everything, and end up with a motor replacement sooner or later...
I too have read most everything on the interweb about IDI motors, I consider it somewhat out dated and not really apples to apples for most builds where more fuel & boost are being added, more power requires a motor that breathes well... but it's just my opinion based on my builds and R&D... I say build what you believe in...
