Will L.
That is a path to follow, but consider this:
Why did the 6.2 become the 6.5? The fuel crunch was still in everyones mind, but power race had begun. It follows with all the gassers too, infact more so in gas cars.
Banks had a friend that owned a dealership and that is why and where he got involved in dealership up grades. Then the surrounding dealerships had to do it to compete. Everyone was willing to pay more a lot more for the added turbo power, because they were not allowed to advertise the improvement in mpg. Banks talked about all that in his interview.
Then factor in changes done for the military. They have no emissions standards. 1,920Brand new optimizers roll off the line every month and have since 2006. Not a single one passed federal emissions standards since 2004.
The diamond precups were a rework of the squares that was a change requested by the military to lessen visual smoke signature on take off in a convoy. They showed that 2 hmmwvs put up more cloud than the Abrams they were following, and 6 was the normal amount to follow.
When GM did the release, I rembember reading about the new precups and that they increase low rpm efficiency up to 2,000 rpm by only a couple percent but had same characteristics from 2,000-3,400 (the peak rpm for military engines). That part was on an update that went out to dealerships, if anyone here works at one maybe they can dig it up. We’ve all read about WarWagon’s 6.2 precups turbo smoke show, and he still cautions 6.2 owners about a big turbo from it. Similar issue of pouring on the fuel to get gowing with too low torque and 15,000lbs of weight.
Also recheck when you have diamonds coming out- they have been in a couple years before then, just maybe not into puckups. My 95 hummer that was n/a (so same block and heads as pickups not the van turbo) had diamonds in it that I reused into the heads on in my 6.5 Suburban.
Since the hummers were assembled at AM General plant, maybe all the diamonds all went to military first few years? Which since the military requested the new design, it sure wasn’t for nox. It is possible they lower nox as a byproduct of burning more efficiently on the lower half of the rpm band, idk.
A set of precups, headgaskets, and head bolts (unless arp already in place and a couple trips to the emissions tester is all thats need for comparisons to test the theory-
