1 in shorter from current belt.
You can see the length of current belt from the part no stamped on it.
Like K061015 means 101 5/8 inches. The K06 means 6 grooves belt.
Sometimes K is replaced by the number 4 for some brand.
After driving the truck around for a few days, it ran fine. Then I had the timing checked. The next day, I installed the Heath programed PCM. Now when I drive the truck, it starts better than it ever did, of course it started well after the work I did too, but just seems better. I've been starting it in 5-9 deg F without being plugged in.
I my experience, cold starting is always better while it's plugged in. Sometimes you just can't. You know, while out deer hunting for hours an hours. I haven't found a currant bush to plug into yet. I don't think we have them here in MN.
The truck runs great now and feels more powerful. I can now reach highway speeds by the time I reach the top of the freeway ramp. Couldn't do that before. We'll check the mileage now too. The first tank after replacing the IP, injectors, GPs and doing the FTB mod, I got 11 mpg and half of that time was spent idling to run the winch for loading logs on my trailer.
