hookedup50
Thats the size Bill sent me and it was to big (K0601000). I ended up using K060994 (99 7/8). Yous may be different, but thats what put the tensioner marks where they should be on my 97.
"1993 CBR900RR-old race bike/street bike, needs overhauling."
Old? I have a 1973 CB750 that I used to drag race with, sitting in the shed. It's still all set up, air shifter and all. Just needs new rubber, fresh fuel and oil (I think).
99.875inI used a AC Delco I believe, #6k994 on a 98.
I stopped by the local diesel shop and set up an appointment for Fri at 10am to check my timing.I would try to get everything correct before putting in the new one. Heath sells god stuff, but any supplier can get bad parts, or make a mistake. If you put in the new one and something is askew, you could be chasing ghosts looking at other things because you make to many changes at one time. Always fix what you know is bad, then move
The local diesel shop checked the timing on my newly installed IP. They said it was at 12* positive (I'm assuming advanced).
Good or bad?
And, -0.75 = how many degrees from ? Sorry for the ignorance, but these are things I just don't know.I would interpret that as retarded as well.
My vote is to get it to OE at -0.75 TDCO (whatever that equates to cam rotation) and let the computer do its job.
. . . . where do I tell the shop to set it? In degrees positive/negative.
