97dually
I would pick someones brain if they do not mind. A couple weeks ago i purchased a 97 3500 6.5 td. it is a 2wd 4dr dually. Right off i noticed it wasnt running right and was spewing massive amouts of black smoke. I figured out the vaccum pump was down and made a turbo master, installed boost and egt gauges. That got rid of the black smoke and helped a minor amount. But going up an incline it is very sluggish. Around 35ish on something my 03 silverado with a 5.3 and 230,000 miles will do 65 up. Seems as if it starts good at bottom kicks and looses power when rpms go up.
Another symptom is it sends alot of white smoke when its first started up till it warms.
I have read PMDs are suppost to have a resistor, mine has been relocated to fender and i received two with it. The one thats plugged in has no labels and no resistor in it (see pic) The other is a stanadyne has no. 5 resistor. Havent plugged it in yet to see if theres any change
Any ideas on this thing may be so weak is greatly appreciated!
