Sparky8370
Do chickens have large talons
Well I got efi in today. The first thing I did was go in and correct for tire size. Then I used the mcrat 20/20 method for starter tunes, although didn't adjust anything for boost because it's an LB7. So that seemed to be going well. Nothing too spectacular. Felt little more than doing the exhaust and filter. So I drove it around for about 7 miles like that. When I got home I found a "clean 100" tune on dp. It was for an 04 so some of the tables were different. It was a different OS so I couldn't script it (or could I?) so I went through and adjusted the tables one by one. Some I didn't do quite the same or just left alone because the ones in the other tune had spikes in the middle of the 3d map. Also, that tune didn't really have any timing. So I used the same method as in the mcrat 20/20 for that, hoping that wouldn't smoke too much driving around. I couldn't figure out how to reset taps, so I figured it would just relearn. I drove around for another 7 miles or so and was being real gentle. I got on an open stretch and rolled into a little. Def not more than 1/3 throttle. As I was doing it I clicked tow/haul. A few seconds later, BAM and the revs went up. I immediately let out of it. The SES light came on and when I got home I had these codes.
p0700, p1781, p0735 Is this tune too big or is it just because I didn't let it relearn? I can tell you one thing, I was barely hitting the throttle and this thing felt like an animal!!!
I was going to put the tune in the tune section so you guys could look at it and tell me if it's really f'd up or if it's just too much for a stock tranny, or if it's even just as simple as not letting it learn. But I don't want somebody to download it thinking it's a proven tune. My stock tune is in there though. (Hey if my laptop crashes at least I've got a back up file somewhere.)
