Hey Will, I know we have spoke of this before but this is the first time I've looked at the oil passage schematic, so it looks like the cam bearings get oil before all but one of the main bearings, so why do the cam bearings fail before the main bearings? See attached pics.I like preoiler/ oil accumulators.
A video of a guy that forgot to turn his on in road corse so one without then with. Watch the oil gauge.
This forum doesn’t see many that road corse, but offroad yes.
There are also people doing diy ones with an electric motor only for pre-start. Simple and provided quality hydraulic hoses are used will never suffer a reason to make the truck break down if it fails. I was thinking about doing electric motor to pre-oil before start, then using same pump for running a centrifuge to get the 110psi but too much stuff to fit in a hummer.
The 6.5 is ok with low pressure according to gm, but we saw them remove the loud cooling fan they needed for nuisance. They removed the numbers from the temperature gauge so warranty demands would be less, then later simply changed spec to a higher number which proved that omcost the military tons of engines.
Of the 6.5 I have seen Torn apart because of low oil pressure, cam bearings is where it went.
yes added cost, and more failure points are added. But
Exactly, by the way are you doing air pressure application of tungsten yet?Life is full of "what if's" what if frogs had wings....then they wouldn't bump their butt...
The bearing coatings stop dry starts, a pre oiler is like insurance to me when I have so much into a motor and my dually sits for months and only gets cranked when I think about it.. and it's only money...
I don't think it would harm a thing, fact is I plan to use one, heck if someone only thinks of the "what all could go wrong" part then why would you risk oil cooler lines at all, could they not rupture.... if someone is that worried they should just leave the motor a sealed unit... but then the oil pump shaft could break...
I think the pre oilers are well worth the cost for someone that wants the best possible protection long term ...
I already have some of the parts from these folks, and will get the rest of what I need from them..
Canton Racing Products | Performance Oil Pans, Coolant Tanks, Accusump, Oil Filters...
Our products solve your engines' oil and cooling problems. Improve your engines oil pressure, oil temperature, and coolant system with Canton Racing Products.www.cantonracingproducts.com
SS Braided 8-AN hose with teflon liner is more than suitable for those lines near exhaust or turbine use fire sleeve cover.Gm being cheap and barely make it out of warranty plan is the issue.
As to the oil hose for a primer or accumulator- anyone gonna spend a couple hundred dollars on an improvement to extend bearing life generally wont use a cheap hose to do it.
Hmmwvs/ hummers oil cooler hose on the 6.2/6.5 doesn’t use those stupid clips. It is regular fittings and hose like would be on a caterpillar or other yellow iron. Money invested in reliability. And thats how to do any oil system- hydraulic hose, which btw is rated for temps higher than conventional motor oil can withstand. The last hydraulic hose I had made was $30. The heat and pressures one would see in this application, the hose should be replaced early to be on the safe side a say every 50 years.
That"s exactly what I was intending on using.SS Braided 8-AN hose with teflon liner is more than suitable for those lines near exhaust or turbine use fire sleeve cover.
Parker makes some good sh_t I've used it myself however, alloy/steel AN fittings and SS braided hose have an excellent reliability history in cars trucks aircraft and in the marine industry too. Knowing what to select for any given application is critical.Better than an open hose- but I dont see why when you have to go to the Rolls Royce to get more expensive-which is this link. You could literally drag this stuff down the hiway, run over it, have it lay directly on the exh manifold and survive.
Most the AN fittings now are lightweight rather than heavy duty. Wanna save weight, drive a honda. Trucks weigh more and resist failure from weaker parts imo.
