ak diesel driver
6.5 driver
Murray is a decent brand name anyways
The 93, K1500 GMC that I had did not have a valve like that. It was a 350 V8.I believe this was a 1/2 ton gas rig thing. None of my 1995, 1993s, 1992, 6.5's ever had that valve. The 1995 350 Gas Yukon did though.
Whoa.... that is not a test. That is a permanent modification to lock up a bad fan clutch. Take out those screws (probably get away with just one) and the clutch will never lock up again.Go to the pull a part, get a fan clutch that fits Your truck. Drill all the way through and install three sheet metal screw all the way through the front and back section. Install that locked up fan clutch and see what the engine temp does.
Will L told Me about that test.
Engine in mine was running 217 degrees, installed that locked up fan clutch and temp would not go over 200.
Have not drove it much after locking the fan clutch. I just never go anyplace except to the store once in a big blue moon. The truck has not been started now for over two weeks. If I do go and aint going to be packing much, I just take the Polaris four weeeeler.@MrMarty51 Just out of curiosity, how much fuel mileage did you loose locking up the fan clutch? I really haven't noticed less power on mine other than the roar and higher boost pressure from normal driving. I'm sure I am having to push the pedal a little more getting the same feel as before with the 6 blade fan and wore out clutch!
