Veg_Out
Walking J Designs
Thanks.  I'd imagine it'll cost more to ship them to me than they are worth.  I'l get a set out west!
I just sent the seller an email. I'm only 30 miles from there.
Worst case, shortblock and and IP, and you are off to the races.
What do you guy's think is a fair price to offer?
I'm not sure on the 1500/2500 difference, anyone know if the 1500 diffs or the individual gear sets would fit my 2500?
OK so it took me a bit longer than a day to get it but.......the axle ratio on the burb is 3:42 (GU6). If you are interested, ill talk to you about it more in the spring when I part it out
It's a 1500 BURB then? The front diff in it should be a 9.25" IFS front diff which will fit right into a 2500, but the rear will be a 9.5"(2500 diesel BURBS are 10.5").
depending on what the interior looks like and the body but with the motor problems id show up with 1000 cash and see where that takes you. i may be completely wrong
I went and checked it out today. Luckily it is close by. It has a broken window in the xtra cab on the passenger side and it also needs a new windshield, tires, sliding rear window, and 2 batteries. The guy said that it needs a new head gaskets. I asked Wyatt (1999 gmc) and he checked alldata and it has the head gasket repair at 16 hours IIRC. After machine shop work, new gaskets, and studs, and labor at a shop here in Sacramento your looking at nearly $2k just for that alone.
Here is how I see it:
In fair condition KBB has it listed at $4600 (this is if it is running).
Subtract out:
$2000 for headgasket Job
$ 800 for tires
$ 600 for windows
$ 200 for batteries
That brings it down to $1000. There is a risk factor because who knows if coolant got into the oil and caused damage there. Plus it has been sitting for 2 years and the inside of the engine could be rusty if the coolant and oil got mixed. I'm thinking $500 to $1000 max. What do you guy's think?
yea...i had noted that above. It is a 1500 diesel. Thats why were trying to see if the parts would swap from a 1500 to a 2500. Or with how much modification
