Jaryd
Extremely Deplorable
The new ones I got from rock Auto was white
I'd get it running right before I dumped a bunch of money in it
I got to wondering if the bouncing of the pressure gauge could be caused by a loose timing chain. Since the pan is off I can see the chain and it’s seems it’s pretty loose.
Is there a spec or a general guideline on how much deflection there should be in the chain?
Anxiously waiting for the report. LOLWow! I could see why you said it didn’t sound right. With a chain that loose and the crank sprocket apparently moving back and forth several degrees.
I’m just going to replace the pump and see how it goes. I feel pretty confident that will be the fix especially after seeing the condition of the pump gears and the rtv on the pickup screen. Just need the time to get out there and get it done.
