Deere65
So a little background first which isn't much but I bought this truck back in the summer with issues it needed injectors, a new crossover pipe, valve covers resealed, boost solenoid, lift pump not working etc. When I had the drivers side valve cover off I seen a drop of coolant in the oil just below where the valve spring sits so cleaned up oil real good and pressurized the system. Yep it was a crack. Replaced head with a new one from clear water cylinder heads. I only replaced that head. And yes I made sure the push rods were in correctly.
After a few miles(like 50 or so) I started noticing the oil pressure was extremely low at idle when hot.(like needle right next to the red). When the engine is cold it holds around 60.
Installed manual gauge and here is what I'm seeing. When cold I'm at 60 just like dash gauge but what the dash isn't showing is how much the pressure is bouncing and after a minute or two the pressure will slowly drop to about 50 and then suddenly jump back to 60 and it will do this several times and then eventually just slowly continue dropping.
So before the manual gauge I figured this was caused by having new stiffer valve springs on one side and that loaded the cam to one side and killed cam bearings but now I'm kind of wondering about the regulator in the pump sticking and releasing until it gets really hot and just stays stuck?
I should also add that the oil cooler was removed by previous owner. I installed one hoping this would help. It didn't.
