davo727
http://filtrationsolutionsww.com/video.html
the demo in particular, filters amsoil's filtered oil, and refilters it clean.
How much are the kits and how much do the replacement filters cost?
Heath sells a kit now, His is $399, but also comes with a new oil fill tube with routing for the clean return.
Filters are 19.99.
As always, could probably do it for less/cheaper, but never easier than a Heath kit.
http://www.heathdiesel.com/T/Chevy-GM/Chevy-9601/Filtration/
For those who havn't watched the video yet, go watch it. It takes FILTERED Amsoil oil, black in color, and filters it out and it looks like brand new clean oil again.
If this is for real, then the test results should be overwhelmingly better I would think. Not to mention its apparently superiour Water separater. Is water really an issue in engine oil?
Even though I haven't lab sampled yet, & I haven't seen video if they are showing oil is clean as new, that isn't true, though the did say may take 2 or 3 oil/filter changes to "clean it up", but oil in my burb with the FS2500 now is black as oil in the truck with the amsoil bypass unit, and I put on a new oil cooler & stainless lines on the burb when I put on the FS 2500 so there was no residual oil in the cooler/lines to blacken the new oil put in with the change .
The recent input has got me thinking. Since mine is what appears to be a full flow dual filter setup. I can't remember who posted the pic w/ a dual setup w/ a regulating spring that is a true bypass filter setup. I was wondering could a spring be added to one w/ a non existing spring? If not where could I get one of those housings w/ the spring?
If you have a machine shop anythings possible, but it would be a lot easier to buy the mount from an amsoil dealer. If you want just want to switch your mount I think the amsoil part is a bk209, probably need some adapters for your hoses. Since the amsoil units are 1"-16 you are limited in your choice of filters. Your other option is to add a single bypass filter and leave your dual full flow alone.
Rodd, i have a single bypass hooked up the same way as davo727 is going to do his, along with a permacool dual filter kit mounted on the frame.
davo727, you dont need to add a restricter to the filter head, the wix and baldwin bypass filters have the restriction built in.
The restrictor is not in the filter. The restrictor is in the filrter housing. You could tap the big hole in your filter housing and install a plug with a 1/16 diameter hole.
