D2 Cat
You're on a down hill run then. You'll have to do it all over again to get the air out.
It cant be that bad with a new IP.You're on a down hill run then. You'll have to do it all over again to get the air out.
I told the owner not to come back to me if his IP or LP fails again,unless he lets me install a gauge and he keeps an eye on it,that did the trick):h.See how your day goes when you get your vitamins?
Those are good pressures. What did you have to do go take a sales course to get the owner to go for the gauge? Did you put in between the filter and the IP? If so, remind the owner to keep an eye on his new gauge (since he's not use to it) and be aware of the pressures as he pulls different loads and rpms. Then he'll get the feel for when to change the fuel filter.
Some don't like the mechanical gauge in the cab. They hear stories of diesel leaks, smell, etc....
I used an electric gauge at first because I had concerns after reading all the BB's stories of fuel in cab. After four changes of the sending unit (and this was a name brand. They sent me all the sending units w/o pay) I removed that gauge and installed the mech.
I had the fancy SS wrapped line to get from the engine to the gauge. It's works fine. No smell, no leaks, no trouble of any kind. You can also buy the "grease gun" hose in lengths to about 36" and do the same thing.
I also went to Geno's and got a big line kit ( which eliminates all the banjo bolts). Then relocated the LP down to the frame rail in front of the tank. Installed a ball valve before the pump for quick shut off. I can change the LP in 10-15 minutes on the side of the road with two wrenches. I did all that 'cause the elec. gauge kept giving me crazy readings. I had a spare LP under the back seat. I'd go on a 600 mile trip and wonder where I could get service if I needed it!
One more thought. Sometimes the gauge will rattle or bounce. If it does the solution is to add a needle valve. Similar to the one the 6.5 has in the WIF drain hose. Turn it all the way closed, then open it about 1/4 turn, that's all. This limits the high pressures surges from getting to the gauge. There is also a fitting called a snuffer ( think it is) that does the same thing. Install it up front near the IP where ever it's easy to install with the fittings you used.
Me stupid:rolleyes5:,i did'nt think about the other banjo's ,yet i had them all off at one time to get to the LP ,to late now,truck is gone allready:mad2:On the banjo bolts, there are 5, I think. Two at the LP, two at the filter canister and one at the IP. If you don't do them all it doesn't get much accomplished.
On my truck ('01) I got the big line kit which is 3/8" or 1/2" hose from the tank to the IP. Removes the banjos for a bigger ID fitting.
On this BB you guys call it "feed the beast" for the 6.5, from what I've read. Pretty much the same thing. Less restrictions, more fuel volume, more cooling, better pressures, less repairs.
