Cumminalong
Doghouse Diesel Performance
All you gotta do is look in the pump gear cover and you can see the key way.
If it does drop, you're gonna have a bad day....you have to pull the front of the truck apart to remove the timing cover to get it.....hopefully it doesn't make it all the way down and end up in the oil pan.....then you gotta lift the engine up a good 4 inches so you can pull the oil pan off.
Sounds like fun, huh?
