Do you have voltage at the solenoid? If so it may be too low due to a high resistance connection. I recall another member had the wiring harness completely burn up under the intake. At this point you are checking the pins at the ECM to make sure the ECM is ok by eliminating wiring problems. Voltage test at solenoid and then following the wiring diagram check voltage at ECM connector. Fix any resistance or opens between the two points by any means necessary including running a new wire clear back to the ECM.
Again the thread pitch of the solenoid is the same as a kitchen faucet aerator.
