I leave the lift pump, with a jumper wire, on when cranking or sitting between attempts. Sounds like the OPS died on you.
Then perhaps you have a secondary problem of not enough heat via bad glows or not enough cranking RPM. Does it sound like it's cranking slower than normal? Yes, then you need to charge batteries or fix the starter and related wiring. IMO jump starting is near impossible on flat batteries.
