Husker6.5
Harbor Freight constantly has coupons in their ads for their cheap VOM free with any purchase. So buy a $1.98 item and get a VOM for free!I completely agree but I don't have enough green lol
Sometimes when you start it it runs wild but dies as soon as you turn the key off, so I know she ain’t a runaway. Other times when you start it. It will run at 1000 rpm and when you press the pedal it surges to 2000 and back down and back up etc. have a good spare pedal and pmd.Now that it starts, what makes you think you need a new PMD or accelerator pedal assembly?
The first time it started it ran great. I killed it so I could hook the driveshaft back up(from being towed with tow bar) and when I started it back up it started doing it. I have a spare manual injector pump and maybe electronic. Also sore injectors. Motor sposedly was rebuilt 100,000 miles ago. Pump and injectors are gonna be last thing I try. Gonna try the pedal first just cause it’s easiest lol. I’ll let you know what happens tonightFrom what little you've described, I'd be.looking hard at the IP being worn out. Unstable idle, "racing" under light throttle, erratic throttle response all point more to the IP than the pedal position sensor or PMD. PMD symptoms are mainly stalling and dying while running, with restart after cool down. Pedal position sensors will cause uncontrolled runaway and/or no throttle response. GM changed the pedal sensor design mid production in '94 to introduce a "fail safe" third sensor to the cluster and changed the ECM programming accordingly.
Didn’t put fresh fuel in. Fuel looks clean and smells good. Fuel filter is ok. Don’t have any service engine lights or service throttle lights on. Not sure about return line but the truck did already run fine once.Paper clip and read codes. Did you drain tank and put fresh fuel in? New Fuel filter? Clean the grounds esp on the IP and the passinger corner of the block has 2 grounds. And as always clear return line to look for air.
Ok I’ll put some fresh fuel in it. I still wanna try the pedal as it’s easiest, fastest and cheapest because I have about 3 of them laying around. I’ll get some fuel still though because of the reasons you listed I’ll let you know how it goes after school todayLook for codes even w/o light. Some don't turn the light on...
Before throwing parts and time at this get it running on new fuel. It's the cheapest thing to try. We have no idea how old the fuel is unless you have better info on that? Old fuel has problems and IP's that are fuel lubed can act up on bad fuel that's lost it's lube. Filters plug. Just saying from the 'major fuel problem king' myself.
I'm having uncontrolled runaway and no throttle response. Turns out it was MANUAL pump pedals that I had. I don't have enough cash right now to try the APPS so I guess this project will be on hold for a while. I'll let yall know if it's fixed as soon as I can get my hands on a new APPSFrom what little you've described, I'd be.looking hard at the IP being worn out. Unstable idle, "racing" under light throttle, erratic throttle response all point more to the IP than the pedal position sensor or PMD. PMD symptoms are mainly stalling and dying while running, with restart after cool down. Pedal position sensors will cause uncontrolled runaway and/or no throttle response. GM changed the pedal sensor design mid production in '94 to introduce a "fail safe" third sensor to the cluster and changed the ECM programming accordingly.
I unplugged it and truck idles better then ever, like I said, won’t have cash for one until October unless I come up with something to do for someone. Anyways I think the APPS will fix it after unplugging it and truck idling great, I have a video of y’all would like to see her running?After going through all this above don't start throwing parts at it now. The throttle (APPS) isn't floored to give you a runaway. I doubt your APPS is the problem. Unplug it and I bet same issue.
PMD's can and are known to fail and cause wide open. So are pump issues. Where is the PMD? Still on the pump or was it relocated to intake or elsewhere?
Also pmd is relocated to intake and I put a spare on and that made no difference. PMD is fine so far. I have PLENTY of other known good pumps to put on it if need be. That’s the LAST resort as it’s most time consuming in my opinion especially without a shop and as limited as I am on toolsAfter going through all this above don't start throwing parts at it now. The throttle (APPS) isn't floored to give you a runaway. I doubt your APPS is the problem. Unplug it and I bet same issue.
