Landon730
Active Member
I'm not getting any voltage on the purple wire out of the ignition switch. So do I need to go to Oreilly and get one? I don't think is the actual wires at this point, I wanna say the ignition switch but I'm not sure. Also I'm not sure where to find one of the books and I don't really have enough moneyWe're back to wiring and, once again, I'm imploring @Landon730 to get himself a set of factory wiring diagrams for his model year to follow along with. Once we finally verify that there is proper voltage into and out of the ignition switch THEN we check for voltage at the input terminal of the Park/Neutral switch when the key is in the Start position.
