ak diesel driver
6.5 driver
be good experience to figure it out plus you'd get alot more money for it
Yeah I'm just completely stumped. I figured out if you press the buttons on the roof light it turns on and if you open the back doors it will come on. If you press str on the radio the time shows for 5 seconds ish but I CANNOT get power to the key, gauges, actual radio, or anywhere else. I'm just at a complete loss herebe good experience to figure it out plus you'd get alot more money for it
Is there a way to check without changing it?I'm wondering if the ignition switch is fried
Ill go take a video of what I have going on and see what you thinkYou should be able to test it with a DMM but again a diagram would be helpful
Not totally sure yet I haven't traced it but Im pretty certain it does because it is a factory wirewhere does the small wire on the starter go to? Into the factory harness?
Did you watch that video at the top of those pictures? I can't get power to the dash either unless the wires are hooked in this configuration but its still not rightSo what I would check next is to see if you have power to the prurple wire going to the starter when you hit the key. If not then I would back probe the yellow wire off the ign switch to see if it's hot when you hit the key
The way the wires are hooked up on starter and that cutoff switch. If I take those wires loose I lose all power at the dashwhen you say this configuration what are you talking about?
I didn’t and that’s how my dads truck is wired to minus the two wires that are in those picturewhat if you temporarily run a wire directly from the battery to that stud on the firewall?
